1 - 15 of 15 Posts
I need to change my valve cover gaskets, most importantly on the drivers side. These 7/16 head bolts have t- bars also. What kind of tool/ socket do I need to get the top ones off. Bottoms no problem. Their is literally no room to get anything on the head. I ground down a wrench but that doesn't work. I can't see where a swivel 1/4 inch would work either. If I ever get them off, I won't put them back on. I have a sizable leak coming from the rear of the drivers side and need to stop the bleeding. Any suggestions would be greatly appreciated.
Super Moderator
What is in the way that you cant get a 1/4" drive socket to work ??? Should be a straight shot. Are they some kind of crazy aftermarket valve covers ? Picture ?
Super Moderator
I guess I should have asked...... what type of vehicle ??
I actually haven't tried the socket yet, but looking at it I can't see any space between the cover and the bolt head. I'm not sure who makes the covers. No brand etc. just chrome. I really don't know how they even got them tight in the first place. I have a ton of sockets but no swivel 1/4 drive. I'll pick one up and try and get back to you. IF I can figure out how to send a picture I will. Thanks for responding.
Super Moderator
Tracy,
I have a set of those cover here and it looks like a straight shot with a 1/4" drive ratchet ?
Well they may be cheap reproduction valve covers where the stamping die doesn't put a sharper corner at the bolt recess to give sufficient clearance. But like was said, a 12 point socket, even 1/4" drive will have a thin wall and probably let you get on there.
Super Moderator
If you cant get a 1/4 drive socket to go on all the way just smack your extension with a small hammer and force it on. Most likely the valve cover will move out of the way anyway if it been leaking.
Discussion Starter · #13 ·
Well I did what you suggest. Went and bought a 1/4 12 point. Still had to grind it and use with my wrench. Nevertheless it's off. Thanks. That helped a lot
Use a different headed screw on the re-install - maybe a phillips head or, if you can find them, screws for the old SBC's using a 3/8" socket and has a flange forged onto it
Allen head cap screws work great too. Jim
Reactions: lloydg1
1 - 15 of 15 Posts
