I recently bought a 72 malibu chevelle. The rear end has some rust holes in it making the seats wet and moldy. I would like to know how to remove the rear seats.
Seat bottom Has two 'catches' one on either side- grab the front edge of the cushion and Push straight back toward the rear of the car(not down)- it should pop up- repeat on the other side.
Seat Back- There are two bolts(or should be) that attach at the base of it which would have been covered by the bottom cushion. Remove those-
This part also has two 'catches' on each side- Push the cusion inward(toward the back of the car), and at the same time lift upward- each catch should pop out and then lift up and out.
If the bottom seat wont come up by pushing real hard,push up the material in the front bottom about 8 inches from each side and you will seat what is holding the bottom seat down,you can simply take a screwdriver and pry against that latch made to the seat and it will come right out.
