trying to take off the front end so I can swap out my ultra rusty rad support. looks like I might need a new inner fender also....any tips to get these cage nut bolts out or do I just need to get a grinder?
Water Road surface Asphalt Wood Circle
Rochester, New York
There's really no trick other than penetrating oil and maybe vise grips. If you can get one to at least start to unscrew - work it out, then in, then out, then in. This will help clear the debris off the threads..... sometimes. Once they break and start spinning - grind away.
Reactions: 69nomad350
yeah they're soaked in oil....can't really get vice grips to stay because they're always at an angle there's not enough room around them to get a nice flat grip. guess I'll grind....and replace the inner fender
Rochester, New York
I just received a new inner fender for my 69. Shipping is a killer for this oversize part!
RESTOPARTS® Manufactured Steel Inner Fenderwells PZ00632-RH
I am very happy with this piece. Restoparts makes good stuff!
