1 - 9 of 9 Posts
Guy's, what is the best way to remove OLD foggy Orange peeling window tint, its about 12 years old and needs to go. Is there anything I can apply to the film to aid in its removal. Thanks in advance.
use your old lady's steamer for cloths ,just did this last week took 45 min each window,,slick as can be try it,it works,
a razor blade and break clean works well
a brick.
Always a fresh razor blade and lube from window cleaner to reduce your chances for scratching. Buy a box of a hundred and pitch them regularly. I like the steamer/ steam iron, heat gun idea.....
Steve O.
razor blade and lacquer thinner
Jeff, Keith, Bill, Steve, thanks again for your help. I went with Mr. 4SPD suggestion because I have all kinds of razor scrapers and a gallon of DTL-105 laying around:D, worked great. I forgot how well Lacquer thinner emulsifies glue/adhesives. Of coarse this was on my DD, not my Chevelle which has SAFETY KOTE , its a great product .
www.SaftetyKote.com Thanks again for everyones suggestions. :thumbsup:
1 - 9 of 9 Posts
