1 - 20 of 29 Posts
Hello, I dont post in this section much, hope you guy's dont mind. My father has a 1971 Monte Carlo with AC, we just removed everything because it doesnt work and he wanted to clean up the engine bay. Not to mention the ease of header and spark plug installs. We installed a OPG AC delete box, the fit was OK and I was suprised it's plastic! My question is are any of the factory plugs/wires needed other then the hotand ground wire for the blower motor? There is also a vacuum line that comes from the firewall I'm wondering about? All help is appreciated:yes:.
I can't answer your question, but don't trash/dispose of the old ac parts.
There worth selling. I remember my dad ripping off the AIR system from my 74 Laguna back in the day and tossing in the trash.
I did the same thing on my '69 chevelle. I took out the A/C box and now I have a ton of wires I tucked into the fender. I would love to hook the blower motor up so I can have heat, but the issue revolves around the resistor...
Where do you put it??? If I plug it into the a/c harness and connect the blower motor everything works great, but the resistor obviously gets pretty hot and since I don't have a huge a/c box anymore, I don't know where to mount it.
.....or possibly, just eliminate it completely and only run on 1 speed.
And no, you can't mount it in the plastic replacement box...unfortunately.
lol, this is has been really been bugging me, I'm a little lost. Also, I just joined the forums today, hopefully I can start making some contributions back! Thanks
whitey70ss, I know on my chevelle I have one longer wire with a rubber "boot" at the end that plugs into the blower motor. If you do this and try to run the blower motor, I get no action. As soon as I plug in the resistor (a plug on one to the 4 wires coming through the firewall for heat & a/c) I have all the variable speeds and it functions perfectly. Now the only issue is that now your holding this 40 year old p.o.s. resistor in your hand as it slowly creeps up in temperature. So I know in my case, if I found a way to mount the resistor and then just organized the wiring mess, I would be happy. It's better than just running maximum voltage to it and having the fan just on high blowing you away inside the car.
HMMMM! Dads gonna be pissed! He was hoping to get rid of all that crap. I'll do some testing tomorrow. Thanks alot fella's, you guy's are awesome!
I found the resistor wire, where is a safe place to mount this thing? can I put it in behind the fender well and zip tie it to something out of sight? Or does it get to hot?
The vacuum line is either for an air door or the heater valve. You probably removed the air door. If your heater valve is non-existent you probably just need to eliminate the vacuum line. One of the slide controls for the A/C heater is a vacuum switch.
Squido
I have a follow on question to this post. (Along the A/C delete topic) I just removed my A/C on my '72 Chevelle and I'm wondering what everyone uses to plug the coolant ports from the intake manifold and the water pump? I'm not a fan of putting a bolt in the end of a cut hose. It just looks so bad.
Ever hear of pipe plugs?
:thumbsup:
I buy them through Summit... They come in red, blue, black, gold/brass, aluminum (polished and unpolished)... Choose a color to fit your car...
This is just one of many choices...
IIRC, the heater hose size is 1/2" NPT...
Buy individually, or in packages...
Also.... aluminum in contact with steel will have a galvanic reaction (electrolysis) going on that will cause the aluminum to seize to the steel or vice versa. It will play hell with the removal later on. One other thing, aluminum in contact with steel often causes galling. If you haven't run across that yet, well, let's just say you don't wanna have that happen cause the threads just ball up with the dissimilar metal causing an awful mess. Best option for use with steel or aluminum is brass plugs.
1 - 20 of 29 Posts
