Let me see - this morning I fill up gas tank - this afternoon, the new sending unit that I've been waiting on arrives...
Is there any gotchas, oh sh*ts, or quick hints/tricks in removing & replacing sending unit? I bought the squeak pads that go on the straps when I pull the tank.
What has to be disconnected that I don't see?
Anything to look to replace while I'm under there? Anything that I can spray on/ coat to make sure that it is quiet when I get done? (there is a lot of noise from the back when I go through a dip or bump - but I can't find anything loose).
Can I do this from the ground, or is a lift needed? I have jack stands, and a floor jack. -
This is gonna be a bonding task for my 18 yr old and myself - what will probably happen is that one or the other of us will have the other in a headlock, pounding away. Since the 18 year old is the weight lifter, I will be use guile and cheating to combat youth and strength...
TIA
>>>Rod<<<
>>>Rod<<<
A.C.E.S. # 2894
Team Chevelle #115
TIA
>>>Rod<<<
>>>Rod<<<
A.C.E.S. # 2894
Team Chevelle #115
