1 - 2 of 2 Posts
The backup light switch is shoot. This is for a 69, 4sp, floor shift, with tilt column. To remove the switch is it just the two small screws that hold it to the column? I think that all I have to do is remove the two screws and lift off the switch and install is just as simple. Will all column switches from 68-72 work? Is there anything special to look out for? Are the switches rebuildable?
Thanks,
Mike
Mike
The factory 69 man trans floor shift back up switch is the same as those used on 70, 71 & 72. The switch is unique to man trans floor shift application. I don't think it is available in reproduction. Maybe try an add in parts wanted .
1 - 2 of 2 Posts
