1 - 10 of 10 Posts
Is there any easy way of removing minor scratches in windows? I have one of my door windows that has a few minor scratches in it. I have tried using polishing compund using a 2" pneumatic angle grinder with a cotton polishing pad without any luck.
Minor scratches can be removed but it's not easy. You'll need some cerium oxide abrasive, a felt bob and a lot of patience. Stick the wheel in a drill motor, squirt some of the cerium oxide on the glass and go to it. Glass is hard so it will take some time but as long as the scratch is not too deep you can polish it out. Keep the speed low so you don't get a lot of heat build up. You can get the abrasive and wheel at McMaster Carr, I think they also sell a kit.
Tom
My best guess is, When you are all done with the polish and buffing.
You will buy some new or better used glass. I am waiting to hear one good story on someone that has had real sucess on polishing and or buffing.
Bob
Bob
As long as the scratch is shallow enough that it doesn't catch a fingernail it will polish out just fine. I polished out the windshield wiper marks on my '62 Tempest and it turned out just fine. The problem most people have is they try to remove too large a scratch or they give up too soon. It's a very slow process but well worth the effort in my case since a new windshield was $700.
Tom
Tom
Thanks Tom for a positive story about removing minor scratches. The glass that I have isn't really that bad, I just wanted to clean it up a little. I'm with you when it comes to saving the expense of buying new glass. I'll give it a try and "then" if it doesn't work I'll look around for some new glass.
Thanks againg for the info!
there a product out their called a 10,000 grit sanding gel it come with a foam pad and a tool that fits a drill, works great it can take the years right off your glass, i think i purchased it at auto zone, but the last time i search there for it was discontinue, you might be able to find elsewhere
1 - 10 of 10 Posts
