I don't have a photo handy, but I have an 18' Anderson Car Hauler with a removable fender that works great. Maybe there's a photo on their website?
I will have to look for pics but when I built my trailer I welded pipes to the bottom ends of the fenders and then a smaller pipe that fit inside it to the frame and put a thru bolt. I held them on tight and were easy to remove. I will look for some pics
My fenders sat and were welded to the step plates. I ground the welds off, and the middle support bracket. I then welded some 1/4 inch rod on the fender ends, about a inch longer than the fender. Than drilled the step plates so the rods go into them and anchor. Then I bought a set off Jeep hood latches, and mounted them. and then on the center brace, drill a hole in it, and then on the trailer frame, drilled and taped it for a 1/4 inch stud, and then use a wing nut to hold it. Works great and easy to remove
