1 - 10 of 10 Posts
Where can i find a relay block.Just a small one.I want to use relays on my headlights,starter sol,fans,ect.
I can't find one..Any leads on what kind of cars i could get one out of.
30 and 40amp
Do a search on this site. Someone posted a link to relays and sockets for Newark Electronics. I think they have exactly what you need.
Yep,i did a search before i posted and came up with nothing.I did a search for that Newark Electronics again and still nothing.
I don't want just relays and single sockets,i want a small bank/block or relays with screw down terminals or something like that.
[This message has been edited by supersport396_2000 (edited 10-12-2002).]
Atlas/Soundolier makes relay banks in 2,4,or 8 banger configurations. The 4 relay unit is about 5"x5" footprint. Their stuff is for 24VDC, but you can order the terminal base/relay socket units sans relays. The sockets follow a standard relay footprint, and you could get 12VDC relays from another source.
Check out www.atlassound.com, and check the "IR repeater, pwr supply, accessory page.
'64 El Camino
383 - TH-350 - 12bolt
4 wheel disc
MN TC picnic
Sonic Boom "Smoke Ring"
Everything you mentioned is under the hood, and many newer cars and trucks have relay banks for these under the hood. I would suggest going that route, as it woould be real easy to remove from a donor, and easier to implement under the hood, rather than under the dash.
Yeah,it was going under the hood..but where?
Hmmmm.......inside the right front fender behind the battery
Sounds good to me,uh,untill i have a fuse blow.
Just put the battery in the trunk.
Hey,thats a good question.What do you guys with the batt in the trunk do with that extra space under the hood?
I had an 89 Olds Calais once that had a nice bank of 4 relays on the firewall. It would have been easy to take those off when I scrapped it.....dangit!
1 - 10 of 10 Posts
