I am taking apart my tilt column, and I was doing fine until I got to the removal of the outer (key) housing. Not sure what it is called. There are 3 screws that I removed, and it moves like it is coming off, but then it catches on something. I removed the key cylinder, but do I have to turn the internal switch a certain way to remove that outer casing. I know someone will know what I am talking about. I can't be too specific because I really do not know what to call everything? Anyway, I removed the cancel cam and the spring and outer bearing, but I cannot do anything from there. I can't see what it is catching on either and I stared at the thing for a good 1/2 hour and wiggled it every which way possible.
