1 - 8 of 8 Posts
Re: Rearend width, axle lengths. 71 camaro 12bolt to 68 chevelle 12bolt
somewhere on here it is said that the 67-69 camaros had the same axles as the 64-67 chevelles
and the 70 and later camaros had the same axle as the 69 - 72 chevelle axles
Total widht 64-67 is 60" 68-72 61". Axle lenght is 64-67 29-9/16" 68-72 30-1/16".
Chevelle 64-67 has same widht as 67-69 camaro, chevelle 68-72 same as 70-72 camaro. So if your 67 has the stock rear they wont fit, but if it has a 68-72 rear the axles will fit.
______________
64 Malibu SS narrowed 12 bolt from a 69
You are the second one to inquire. I need to iron out the details with Troy before it gets discussed. I have no use for it since I don't have a 2nd gen camaro. BUT, the axle tubes have been welded to the center section and have a little twist to them. The camaro it came out of has been 9.60s at 130+, so it's had a rough life. If you are still interested, PM me and I'll let you know how the deal works out. If it falls through with me, I'll put you in contact with the current owner, he's in the St. Louis area.
TJ
1 - 8 of 8 Posts
