Converted over to a quick performance 9" that I should have in the next week or two and I had a couple questions about initial setup. Could you guys share where you have everything set to right now so I have some kind of starting point. One thing the previous owner had on the 12 bolt were the no hop bars attached to the housing. He told me unless I have the ears mounted up higher to mimic the no hop bars that the car won't lift on the hit and will never 60ft properly. Car had a best time of 9.67 before I literally replaced everything in the car to handle the new setup. Any input or base settings (which bolt holes to choose with upper/lower control, pinion angle etc.) arms would be much much appreciated as I am adding additional goodies. Below is the old setup and how I am configuring the new rear end.
12 bolt
Stock upper control arm bushings
No hop bars
Adjustable rear upper control arms
Non adjustable lower control arms with stock mounting brackets
Shocks moved inboard vertically
UMI drag anti roll bar
QP 9"
Spherical aluminum upper control arm bushings
TRZ adjustable rear upper control arms
TRZ double adjustable rear lowers with double adjustable dual rod ends
QP adjustable lower control arm mounts
TRZ anti roll bar (above axle)
12 bolt
No hop bars
QP 9"
