Ive put myself in quite a predicament. My keys are locked in the trunk and the locksmith says the only way to get in is to remove the rear seat. The only problem is that he wants $200. How do i do this myself.
thank you and please help
MadMalibu1970
First you have to remove the bottom part.
You do that by pushing down on the seat itself and forcing it back (to the rear of the car) After you did that you can raise the seat up, and just take it out.
Oh.. Don't forget to get the hand rests off before doing that...
After you got the bottom part out, you'll see the bolts that hold the top part. (where the top part meets the bottom part..)
If the seat was never removed.. It might be hard.. (Rust maybe got it jammed over the years..)
Shai
1972 Chevelle Malibu custom 4dr
TC member #1278
ok i have the bottome out and the bolts off of the top section. I cant get the top section off for some reason. I found an old post after i posted this one that said to lift if off of the hooks at the top, but i cant seem to get it off.
