I have a real headache with a leaking rear main seal on me fresh engine. I beleive it is the seal, but have also been eyeing the back of the oil pan. You can see oil on the crank end, but cant tell if it is the main seal or the pan seal.
Here is what I have done in the last 1,000 since I first started the engine and notices the small but irritating leak, requiring me to pull the engine 3 times.
-changed oil pan gasket 3 times, used cork first time, 1-piece rubber the 2nd & 3rd time
-tried 2 different oil pans. The one on their now is an expensive Stef's fabricated aluminum job
-disassembled the engine, pulled the crank (brand new Eagle 4340 crank) and put in a second new rear main seal, taking care to off-set the seal parting line both times
-Check all other potential leak sources, using flourecent leak detection dye. I beleive it is the rear main.
I am totally stumped and aggravated after all this effort, it is still leaking all over the shiny clean bottom of my car.
The only remaining thing I can think of is the crank is machined wrong from the factory where the seal rides. I only use Fel-Pro seals. Any ideas??!!!
By the way, does anyone know if the Stef's pan uses a thick or thin front seal on the pan gasket? I am using a thick one as instructed by Stef's but the guy seemed very unsure of himself. I measured the gap and it seems like it needed a thick one, but the pan went on awefully tight in the front. This is not the leak issue mentioned above, though.
