Here's the setup I have:
1968 elcamino custom
496 BBC stroker motor aluminum heads 600ish lift cam 10.5-11.0 CR roughly 600 hp 700lb tq ( estimated )
th400 with lower first gear than stock with 2500ish stall.
energy suspension poly trailing arm bushings
competition engineering traction bars
stock shocks
stock springs
3.73:1 12 bolt positrac rear end
275 60 15 tires on 15x8 rims 4.5" backspace
seems like every time I give it any gas the rear breaks loose and I have to seriously feather it. I want to be able to cruise it on the freeway out of town but I don't want to loose alot of bottom end.
Is running a 3.08 rear gear going to severely rob my hp and tq? What are some of the BBC trans rearend combos that have been successful for you guys?
It seems like I could run a gear vendors overdrive but 3200$ is not on the budget as of now. Maybe I can find a happy medium until then?
stock shocks
stock springs
