Hi guys, I just picked up a 69 Chevelle rear end housing. The only issue is the shock absorber mounting brackets were cut off at the bottom. There is no longer a hole to mount the bottom of the shock absorber. I was hoping that someone could post a photo of a stock bracket with the dimentions and the size of the hole.
Thanks a bunch for your help!
Pat
It's 5 1/2 inches from the top of the bracket to the bottom and the center of the hole is 5 inches from the top. The bottom part of the bracket is angled a little different from the rest of the bracket. The center of the hole is 1 inch from the outer edge of the bracket and the hole is 1/2 inch.
697973
697974
697975
697977
697978
Discussion Starter #5
Thank you, Thank you, Thank you!! Ill be making a couple of brackets tomorrow!
