Can you figure out the ratio buy spinning drive shaft by hand and counting times rear tire turns around. I tryed and got drive shaft one revolution and 1.25 on the tire. Maybe i did something wrong it is in 1971 malibu build sheet says it has a 2.56 rear end.
When I did this, I got the same result. 1-1/4 turns. There is something about having an open carrier (non posi) that makes it to where you have to double the rotations to get the ratio. With that being stated, 1.25 x 2 + = 2.50, which is really close to 2.56.
Looks good to me. Well, as good as having a 2.56 open gear can be.
I want mine changed out so bad, but it isn't a cheap undertaking. :noway:
I just rebuilt motor and tranny in # matching 71 malibu put 202/160 valves in heads to keep original heads mild cam 9.15-1 comp. and i'm getting 16 mpg on highway but i get that mileage with my big block impala 427 4-speed 3.73 gears. Do i need to get higher gears in chevelle to get into power band on motor?
