7.) Now it's time to install the springs.
Each spring has one rubber isolator that installs on the top of the spring, between the top of the spring and the pocket that the spring is placed into. There is no isolator on the bottom of the springs.
Lower the jack so the rear end travels downward as far as it will go. Then, with the isolator on top of the spring, push the top of the spring into the upper pocket and then lift the bottom of the spring onto its seat on the rear end housing.
Then do the same on the other side.
If you're having any trouble getting the spring to fit into its location, you can slightly jack up the opposite end of the axle housing.
As you begin to jack up one end of the axle housing, the opposite end will begin to travel down, thus giving you more room to maneuver the spring in.
8.) The final step is to simply jack the rear end up until the studs on the bottom of the shock absorbers are lined up with the mounting holes on the rear end housing, push the studs through, put a nut and washer on them, and you're done. :beers:
If you've been thinking about installing a rear end in your car, don't let it intimidate you.
As I said earlier, I did this job completely by myself, no helping hands, and using the procedure outlined above it went in very smoothly with no hassle.
Regards,
-Greg
Regards,
-Greg
