hey people,another question,been having a time with bushings on rear lower control arm,bolt will not come out,so i cut off bolts and burned out rubber bushings,all nice and clean and painted,anyhow,here the problem,new bushings came,g.m bushings,well they are in a metal casing like on the control arm,do i remove the casing on control arm?,and how do u do this,or remove the bushing from new bushing casing,and how to do this,and put in old metal casing,thanks again to all,
You will have to remove the thin metal sleeve left in the control arm from the old bushing.I had a similar problem with my sons pickup.We used a dremel tool to cut the old sleeve and then it tapped right out.We then used a large vise to install the new bushing.We greased the outside of the new sleeve to make it press in easier.Hope this helps, Jerry
66 El Camino 350 4 speed
68 Nova 454 4speed
http://community.webshots.com/user/11011954
You could also freeze the bushing and heat up the contlol arm and this makes the press fit a little easier. I have done it several times and this has worked the best for me.
Good Luck
Nathan Brandt
The more cubes the better!!!
70 SS 396 4spd under restoration
71 SS 454 clone 8.8 1/8 on pump gas and 8" slicks
60' 1.949 & 77 MPH
Team Chevelle # 1143
My 71 SS 454 clone
[This message has been edited by Nate (edited 12-07-2001).]
