Has anyone built their own rear disc brake conversion bracket for a 1970 Chevelle? I am going to use the stock rotors and calipers that came off the front after upgrading with Willwood.
What's the plan for the emergency brake. Required by law in some localities.Has anyone built their own rear disc brake conversion bracket for a 1970 Chevelle? I am going to use the stock rotors and calipers that came off the front after upgrading with Willwood.
Not sure if I am reading this right, but are you trying to say you want to use the front brakes that came off the car on the rear by fabricating your own bracket after you have upgraded the fronts to Wilwood?Has anyone built their own rear disc brake conversion bracket for a 1970 Chevelle? I am going to use the stock rotors and calipers that came off the front after upgrading with Willwood.
that is correct, the car came with factory discs in the front. I am assuming that the factory rotors from the front will work on the back along with the calipers, 12 bolt rear end.Not sure if I am reading this right, but are you trying to say you want to use the front brakes that came off the car on the rear by fabricating your own bracket after you have upgraded the fronts to Wilwood?
That is what I readNot sure if I am reading this right, but are you trying to say you want to use the front brakes that came off the car on the rear by fabricating your own bracket after you have upgraded the fronts to Wilwood?
Ok. That will not work. Factory front disc brakes will not work on the rear. You need a completely different setup.that is correct, the car came with factory discs in the front. I am assuming that the factory rotors from the front will work on the back along with the calipers, 12 bolt rear end.
Excellent, thank you for the help, I know what to do now.Ok. That will not work. Factory front disc brakes will not work on the rear. You need a completely different setup.
