I have a 70 SS Convertible. I have removed the rear end to be rebuilt. The rear end appears to be from a 68 Chevelle SS based upon the codes (3.08 Posi 12 bolt).
When I removed the rear coil springs, I found that the springs were bolted to the differential saddle (which is completely flat) by a bolt and homemade heavy steel plate acting like a big washer.
According to my 70 Factory assembly manual, there appears to be a cone shaped disk that is a part of the saddle to hold the bottom of the coil spring in place without any bolt or retainer used.
1) Is this correct? Does the weight of the car just hold the bottom of the spring in place?
2) As I am ordering new springs, should I order for a 70 and try to fabricate this cones shaped disk and weld it to the flat saddle? Or should I order for a 68 and try to get the proper retainer washer and bolt?
3) If I go the 68 route, where can I get this retainer washer and bolt? I have not seen it any of the parts catalogs, Ground-up, OPG, Muscle Car, Auslies. Year1 etc.
As always your help is greatly appreciated.
--Andy--
1970 Chevelle SS Convertible
1937 Master Business Coupe
1996 S-10 Blazer
Yup, I'm Chevy Prejudiced!!!!
--Andy--
1996 S-10 Blazer
