1 - 17 of 17 Posts
My build has been done for almost 2 years now. I have noticed that the car sits to level, no front rake. It has all new front suspension using UMI springs, tubular control arms, upper and lower, with a Fat man 2” drop spindle and some stock shocks. In my infinite wisdom i used some original rear coil springs from a 4 door donor car. I feel these springs are likely compressed some which is giving me the level look. I’m thinking that a new set of UMI rears will give it a lift. I know there are a-lot of variables in trying to figure out this question but does anyone have an idea how much they would raise the rear of my “64”? Car is sitting on a bit of a hill may be misleading to the eye, but on a level surface it measures 6 1/2” all four corners.
Tire Wheel Sky Car Cloud
1966 El Camino: 283, TKO500, 3.36 posi.
I have UMI adjustable tubular A-arms with Fatman 2”drop spindles. I ditched the springs and went with Viking double adjustable hybrid coilovers.
Looks like the jury is back, i will leave it as is. Was a little concerned as we are taking it to Cruising the Coast in October(650) miles and the gf packs the kitchen sink, thanks for all the replies.
Is there some kind of air bags can be added for the GF's goods?
A guy gets to his hotel, gets himself a crane, unloads, and then deflates whatever device maybe could do that?
My Dad had that procedure and didn't ask the Doc how to Deflate for a month or so LOL :ROFLMAO: :ROFLMAO: :ROFLMAO:
Air Lift bags inside your rear coils will solve your problem without the car going "droop snoot" on you, Summit and others carry them, don't need to go crazy on air pressure, around 5# unloaded, 10-15# loaded should do the job nicely, some people have 2 separate air fills if going to go drag racing, otherwise only 1 fill should do nicely...used to be under a $100, an hour or two so to install and run the lines, if you have the tools. Good luck.
Discussion Starter · #17 ·
Thanks going to look into this
1 - 17 of 17 Posts
