1 - 15 of 15 Posts
And it really was pretty much "painless" I also upgraded to a powermaster 140 amp alternator, as I plan on running several electric loads.
I wired the car up with an 18 circuit kit, and if anyone else is planning on doing this, and needs help or advice, please don't hesitate to drop me a note.
I also installed headlight relays, one running all 4 low beams, and one running all 4 high beams. Those lights are SUPER bright now, I love it.
I also converted to all electric senders on my gauges, and used the gauge harness from painless. Pretty trick, and it looks great as well.
I paid 279 plus handling for the kit from Summit. I also bought a new ignition switch, wiper switch, and a courtesy light kit, but those aren't needed. The relays and bases ran me 10 bucks each, and then the fuses and blocks for them ran about another 3 each. I did buy some extra wire and a ton of other connectors, as the ones supplied by painless seemed to be a little on the short side numbers wise. I think all in all for everything, I have about 400 bucks into the re-wire. That's including the gauge harness, which was like another 40.
It was totally worth it though, as my electrical system runs like a late model car now - which is good, because this is my daily. I also plan on adding power windows and locks, and the painless kit already has that wired up. Same thing with the AC compressor, and all the heating / cooling controls. Plus, it has the newer style fuses, and it looks a lot cleaner than the original wiring harness.
And, if you guys need any help with it, give me a ring at 619-807-8633. I'd be more than happy to help you guys.
I was fortunate enough to buy the brand new harness in the box at the Delmar Swap Meet for $75. I wasn't aware that they were $280 new until I looked in the Summit catalog when I got home from the swap meet. I guess there are some bargains out there. I usually dont' stumble across them.
I don't think so - but I didn't go over it wire by wire to check out the actual wire gauge vs. what the instructions said. It could have - I just didn't notice. When I was wiring it up, I just looked to make sure that the size of the wire was relatively correct for whatever I was landing - i.e. the ignition wiring is larger than the instrument light wiring.
Overall - I'm extremely happy with this kit.
Oh geez - sorry I missed that, yeah, it would make it much easier if you removed the dash bezel - I wouldn't take the whole dash itself off of the firewall. I didn't. I did take the seat out though so I could maneuver inside the car easier. If you'd like, you can check out :
Pictures of Painless Wiring Kit install
There's some pictures and stuff of the whole deal. I'm almost done tucking everything away in the engine compartment, and when I am, I'll snap a few shots of that and post them too. Overall, I am super happy with the way it came out.
Looks good!
Wayne, I wish I could have found a deal like that. I ended up buying spools of wire and making up my own for a little more than you spent on the kit. I used an ARC fuse panel from Jegs. Wiper and headlamp switches are from CenTech.
I really like the dual headlamp relays with all four low beams. And 4 halogen brights at full voltage are awesome for showing some oncoming idiot that you don't need those blue/white "euro" lights to blind oncoming traffic. ;)
1 - 15 of 15 Posts
