-Excellent 1970 Chevelle AM/FM Stereo. Factory Original Delco Radio 01BFM1.
-This is one of the nicest original examples left out there.
-Ready to be installed.
-This is the AM/FM Stereo unit with 4 speakers not the lesser mono unit.
-Stored properly and was removed from low mile chevelle.
-There is nothing on the stereo that needs replacing and everything is factory correct.
-Clean inside and out.
-Unit has been fully looked over, cleaned, lubricated and tested by a knowledgeable vintage stereo repair shop(same shop I restored my rare Marantz 2500 etc with). It has zero issues and he said it works as new.
-Has all original metal body that looks basically as new(not restored), original black tape on the body, original knobs, original face plate, AM/FM numbers are all nice/clean, nothing faded, original model tag is even still present and in good condition which is rarely seen.
-Everything works, lights up, all 4 speakers work(front/rear both tested and sound/work great), fade etc works, AM/FM is both nice/clear with good reception and sounds great, tuner dial works, volume works properly, preset station selectors all work, etc.
-Bonus that it still has a original harness. Will need a few wires spliced but the plug is nice. You can also easily get the harnesses new as well.
-You can spend the money/time restoring or modifying a rough core if you can even find parts or get one of the nicest original examples out there right now without waiting.
