So I finally got around to putting my keystones on my car and have a problem with the rear ride height and was wondering how I would go about raising it. I replaced the shocks like 4 years ago but the coil springs are the originals. The tires on the rear are 255/60/15 and the lip of the quarter is sitting like 1/2 inch above the sidewall but if you push down on the trunk it goes right into the sidewalls. I'm assuming my coil springs are shot cause they're so old but I don't really know what kind to get. Do they make heavy duty springs or would big block springs make a difference? I kind of want to raise it an inch or two cause I need new tires on the back plus they're 60s and the fronts are 75s. Which also has me wondering whats the biggest rear tire you can fit on a stock 70 chevelle. Thanks.
Stock wheels
15x4 keystones 215/75/15
Kind of how I want it to sit These rears are 255/60/15
If your only looking for an inch or two, i went with air shocks. Simple, cheap and you can lower it down by bleeding the air out or raise it by pumping it up. Just like you would your tires. I have my valve stem attached to both shocks and i mounted the air valve under my licence plate on the rear cross member. If your tires are rubbing on your inner fender lip you might want to try a different offset for your rear rims or have the fender lip smoothed by a professional body shop to run the wide tires. Stock springs worked fine for me. Hope this helped, good luck
· In Memoriam
raise the rear = wheel hop city. ruins the rear suspension geometry immediately. Hasn't changed since 1964.
call these guys ..
LINK LINK
give them your inside spring dimensions and they will give you a set of air bags for $80 or so. I've used them in Jeeps and had good luck getting a inch out of it when a winch made front sag.
Yeah not really worried about wheel hop as it's the stock 350 and one wheel wonder. I'll probably end up putting a big block in it with posi but I'm not going to really be racing it anyways. I was thinking either air shocks or air bags. Idk yet though.
they still make regular air shocks?...i still have the original hardlines on my el camino.
remember when hi-jackers and lakewood ladder bars were the state of the art in bolt on rear suspension?....ahh, that takes me back.
Reactions: Befenz
As does mine, but not the original air shocks, and yes, they still make them. Monroe Max-Air MA762. About $60 for the pair from Rock Auto. Includes air line and fittings. I literally just unbolted a well used set from my EC. I'm trying to do away with them (got new stronger springs and new shocks to go on).
