The radio shuts off momentarily when I hit the brake. I think I remember this hapening when my alt was going south on a different car, what do you think? :confused:
Unless it's hitting a wire while the pedal is depressed, don't see it off-hand. If it's not that, think I would first check and see if the car has a good body ground. This is a wire that runs from battery (-) to the right inside fender. If that's there, try a adding a jumper wire from the radio frame to the dash frame. See if that stops the problem.
Administrator
Rare option, a safety feature that keeps you from being distracted while braking, on the big block cars it also shut off the radio during wide open throttle.
