I have the dual ford windstar fan setup in my car. I have the ground for the relays going through a switch on my dash. My stereo is a kenwood cd player using the in windshield antena.
When I turn the fans on, my radio picks up interferance on the FM signal. Is there any way to prevent this?
Chris Dagenais
'71 Malibu with a home built 454!
"Our balls are bigger :)"
My Page
This is probably caused by the commutator switching (brushes moving from copper bar to copper bar) in the motor.
Put a capacitor between the power terminals at the fan. The value isn't real important. Probably an electrolytic in the 10uF range would work.
You could also just use a condenser from a points distributor. Just connect the wire to the +ve fan terminal and mount the case so it is grounded. These things protect against points switching noise which is much the same thing.
Peter
Your fan is introducing noise into your "system" but it won't affect anything.. other than your radio
The above mentioned "noise filter" can be purchased at Wal-mart. do you have those?
I have one between my fuse box and my radio (supply wire of course).
What it consists of is a capacitor and an inductor. a little 1" cubed box, about $10. I run race plugs (more feed back) and it takes care of that noise too.
-when I first bought my car the radio picked up noise from the ALT. so I had a high pitch "whirring" porportional to RPM. with the radio turned up on and on "aux" (nothing), it sounded like a blower
pretty fun for one weekend.
71' 3880# with me. Big Block 402, Merlin oval heads, 10.2:1CR, TH400, 3.73 posi,
BEST 1/8th: 8.252 @ 84.56mph (1.855 sixty foot)
Last years previous best 1/4: 13.1sec @ 105 MPH (2.10 sixty foot) to be corrected soon.
Picture of me roasting the tires and other guy stuff
Video of me staging (smoke of course)
