3/4" and no shroud is good, if you run a shroud the fan blades should be 1/2 way in (or out) of the opening. Putting a shroud on and leaving your fan where it is will be of no benefit. The shroud acts like a funnel allowing the fan to pull air in across a larger area of the radiator.
Philip
