My 454 came with the big flywheel. I am assuming that there is only 1 flywheel size that comes with a big block (with 4 speed). My question is: Is the big flywheel machined for either an 11" or 12" clutch?? I don't remember if it had two sets of holes for 2 different size clutches or not when I dropped it in the engine bay, and I have to wait until I have time to get underneath it to check it out again. I bought a 12" clutch, and I didn't know that there would be problems finding a bellhousing for it.
thanks
Joe
1965 Chevelle SS
Not for sure on big block stuff, but....
My SB has an aftermarket big flywheel, and it will take both 10.5" and 11" clutch. I think you would have to have a "special" flywheel for a 12" clutch. I don't think cars normally use 12" clutches. I've been reading about trucks using 12" clutches, so maybe you need a 12" 454 truck flywheel. I'm sure somebody knows for sure...........right guys??
chris
AS FAR AS I KNOW, THE BOLT PATTERN ON A BIG, 14in DIAMETER FLYWHEEL, REGARDLESS OF WHETHER IT CAME OFF OF A 350, 427 OR 454, CAR OR TRUCK, WILL ACCEPT EITHER AN 11 OR 12 PRESSURE PLATE. I once had a 12in pressure plate in the shop, but I must have used it for a core trade-in on an 11in pressure plate. Although, I do still have the 12in clutch disc. THE 12in DISC EASILY FITS WITHIN THE BOLT PATTERN FOR AN 11in PRESSURE PLATE. As I recall, the bolt holes on the 12in truck pressure plate were tucked in real tight to the pressure plate. Therefore, as I said, I'm sure both an 11 and 12in pressure plate use the same bolt holes on a big, 14in flywheel. But, for a car application, I just don't think you need the bigger, heavier 12in clutch. That's an awful lot of mass to spin at the rpm of a medium or high perf engine. Truck motors don't spin that fast.
And also, I DO NOT BELIEVE anything bigger than a 14in flywheel can fit within the confines of the truck bell housing. So, if you have the big truck flywheel, use it with an 11in clutch. Remember, a 454 flywheel is EXACTLY the same size as a big flywheel used on a 350-396-427, but the 454 flywheel is all by itself because of the required extra weight on one side for balance purposes (if you are building a SB400 with a 4sp, use a 454 flywheel on the SB400 and just have it balanced with the engine, because flywheels for SB400s with a manual tranny are super scarce).
Tom Parsons
