"P" Terminal (Phase Connection) - This terminal sends a signal to a relay, frequency sensing tachometer, or computer indicating alternator speed. This terminal may not be used - this is normal.
"L" Terminal (Charge Light) - This terminal is fed from the ignition through the charge light on the dash. This is similar to many other charging systems. This connection turns the alternator "on". Without a signal to turn "on", the alternator will not charge. However the "I" terminal may be used to turn this alternator "on", as described, instead of the "L" terminal. Please note that if
there is a connection on the "I" terminal there will be NO connection on the "L" terminal.
"I" Terminal (Ignition) - This terminal is fed directly from the ignition switch to turn the alternator "on". Without a signal to turn the alternator "on", the alternator will not charge. However the "L" terminal may be used to turn this alternator "on", as described, instead of the "I" terminal. Please note that if there is a connection on the "L" terminal there will be NO connection on the "I" terminal. If there is a connection on the "L" terminal AND the "I" Terminal THEN the "I" terminal is NOT an "I" terminal but an "F" terminal (confused yet??).
"F" Terminal (Field Monitor) - This terminal sends a signal to the computer telling it how much field current is flowing (therefore the computer knows how hard the alternator is working). This terminal is not always used AND can only be used if the alternator is turned on by the "L" terminal.
"S" Terminal (Battery Sense Connection) - This terminal is larger than the others and provides the alternator with a precise battery voltage reading however, this connection may not used. When not used, the alternator will automatically sense battery voltage at the battery post.
