If I remove the main brake line coming off of the master cylinder for the front brakes and then reinstall can I get away with bleeding the front brakes only?
Because if I only remove just the front line and not the back it's not allowing air to the rears correct?
You'll need a plug of some kind, anything will do as long as it fits in the hole. Check in the parts store, they might have something that fits... or ask them nicely if you can rob one off a new m/c. ;)
