Hi Folks-
Well, after a fun filled day of overheating on the way to the inspection lane, I am going over all of the engine compartment wiring, including the electric fans. Apparently, the fan was wired with two parallel 30 amp fuses (glass type) from the alternator. These fuses managed to get hot enough to melt to their fuse holder, the plastic cylinder kind. What type of fuse would be adequate to prevent this from happening again? Should I tap the power off of the battery instead of the alternator? Overheating sucks!
Also, under the dash I found a bundle of clipped wires that are gray, yellow, and black. Any leads?
Thanks!
Thanks!
