1 - 9 of 9 Posts
I have been trying to de-code the engine in my '71 chevelle malibu for some time without any luck. Everyone tells me that it is a matching numbers car for '71 but they claim that a ccc engine did not exist for chevelle in '71. Numbers are as folows: vin#136371B117990 engine code#'s: 11B117990 10908ccc. I know everything about the car except for the engine. It has a 4bl carb on it. I was told it was a 350 or 307, and that ccc engine code did not exist for chevelle in '71. ????????????????
You might have a restamped engine, although if they were bright enough to put the correct VIN #'s on it you would think they could get the code right. How long have you had the car? Did the previous owner make a big deal about it being a matching #'s car? Get the block casting # and build date from the bellhousing area of the block and post them here.
Steve Strasemeier (70SS)
Are you sure it's CCC and not CGC? Even though it has a 4bl if it's CGC it's a 2bl 350, 245 hp block for 1971.
Yuri
Discussion Starter #4
Thanks for replying. I'll check on those numbers. I have an old Chilton manual that says only nova's were stamped with ccc, and not chevelle. This one has got me. Would they have put a nova engine in a malibu?????
Discussion Starter #5
The block actually says "T"0908ccc. I was wrong about the 1. The valve covers say Tonawanda which matches the T. The fan shrowd says 350 2bl. If the engine block has been re-stamped incorrectly How will I ever be able to tell the size of this motor? Did any 350ss come with a 2bl? I am positive of the ccc. The search goes on.....
Indeed Chevy did make a 350, 245hp. This was a very common power plant for the 71 nova with air conditioning. 350, 2bbl, 245 hp.
Discussion Starter #7
Thanks for the thoughts. I have come to the conclusion after calling year one that the engine is a ccc 307, said only to come for nova that year in my chilton book, but Year One tells me chevelle as well.
Dennis,
If you're still not sure about your engine, send an e-mail directly to Chevy. You can do this by going to http://www.chevrolet.com and "Talk to Chevy". That's where I found info on the 350 in my 72. They'll tell you horsepower rating, carb size, etc. Hope it helps. Good luck!!
R
Guest
Dennis
According to my domestic interchange manual, which has never failed me in 15 years, CCC refers to a 307/200HP installed in 1971 Camaros,Novas,Chevelles, & GMC Sprints. I'd say Year One has it right.
1 - 9 of 9 Posts
