I know very little about body and sheet metal work. I know two guys that I can ask about this, but I want as many opinions, viewpoints, and advice as possible, so here it goes:
If I wanted to attempt to have a safety shield to contain a possible automatic trans front drum, flex plate, or torque converter explosion during drag strip racing from going through the trans floor tunnel and severing one or both of my feet, what would be the thickest piece of steel that a body fab guy can contour into the shape of the transmission floor tunnel, with an english wheel or whatever else is used for bending and shaping body parts? Would 1/8" thick mild steel be way too thick to do this with? If so, what about aluminum?
Like I said, I know very little about body work, or sheet metal work in general. I'm wondering if I can have two pieces of mild steel fabbed and contoured into the same shape as the trans tunnel on my 70 Chevelle. One to fit snug on the outside, underneath the floor tunnel, and one to fit over the tunnel inside of the car. I would then drill matching holes around the circumference of both the pieces, and then bolt them together once I have them placed under and over the floor trans tunnel to sandwich the tunnel in. It would be a double wall sandwich of mild steel,(or aluminum if need be). Would this be possible to fabricate? Or am I dreaming? If this is out in left field, don't shoot me. I'm just trying to think outside of the box here.
Just brainstorming right now. The two fabbed pieces would have to fit snug to the the floor tunnel, and follow it's contours closely. Especially the outter/bottom piece which would have to fit between the top of my TH400 transmission, and the bottom of the floorboard trans tunnel. If there are any shops or interenet sites that sell something like this already fabbed specifically for GM A-body cars, then please make mention of that. I haven't found anything like that.
