Team,
I know that when you go from a TH350 to a 700R4 the mounting points will move back 3 inchs. I looked at my frame rail where the crossmember is currently bolted up. It has holes drilled all down the rail (from the factory I hope). I was hopeing on of these was magically 3 inchs back. This is not the case. I would simply drill a set three inchs back from the original, but that frame is going to look like swiss cheese. How have you guys handeled this without buying a new crossmember?
