1 - 2 of 2 Posts
I HAVE A 1970 CHEVELLE THE BATTERY KEEPS DYING IVE REPLACED VOLTAGE REGULATOR ON THE RADIATOR SUPPORT , ALTENATOR WHAT ELSE COULD BE CAUSING THE PROBLEM IVE ALSO RELACED THE REGULAR BATTERY WITH A YELLOW TOP OPTIMA AND STILL HAVE THE SAME PROBLEM
Start by putting a volt meter on the system and see if it is charging properly. Also, check for a drain condition that is discharging the battery when the car is not running, like a trunk or glove box light that is always on.
1 - 2 of 2 Posts
