There is a screw at the bottom that holds the metal channel to the window frame. Remove the rubber then remove the screw. If the metal channel can't be pulled off the edge of the glass you can lightly tap it with a block of wood and a hammer. No need to get He-Man on it, it should move pretty easy with a few light taps.
