I was tuning my Quadrajet.....ran the idle mixture screws all the way in and started backing them out a quarter turn at a time on each side I got the highest vacuum reading at only one turn out, does that make sense? One turn out meaning a full 360 revolution of the screw.
· In Memoriam
that's a little unusual for a Q. Is it an early carb, from the 60's?
Tom,
Thanks for the reply. Actually the carb is a 71, I think. Seems to me that only one turn out would be a little lean. If I get beyond the one turn, the vac drops and the engine starts to run a little rough. Same thing if I go back in with the idle mixture screws.
· In Memoriam
somebody may have drilled out the idle feed restrictions or something. normally I expect at least 3 turns on Q's.
· In Memoriam
yeah, but if somebody drilled the idle feeds that big there may be an issue with the idle air bleeds being too small in comparison.
That will sometimes affect idle quality, like dieing going into gear. But, if it runs and idles good your good to go.
