I have a friend that picked up a carb to rebuild.
What I know so far:
---------------- 17059216 ----------------
* 170 (means after 1976)
* 59 (means 1979)
* 216 (is the Emissions, Division and Transmission)
**2 is for 49-state Emissions
**Division. 0, 1 and 2 are Chevy
**Transmission. Even numbers are automatic trans
Make & year Chevrolet, 1979
Displacement/cylinders 350/8
Carb number 17059216
Primary jet & rod combo NA / NA
Secondary jet & rod combo 0,135" / NA
Idle feed NA
Fuel inlet valve 0,135"
What does the raised code below it mean?
--------- 0685 CMA ----------
Is it the 068th day of 1975? What is "CMA"?
What is the CFM?
Can I tell what type of car it came off (model wise)?
DG
What I know so far:
* 59 (means 1979)
Idle feed NA
What is the CFM?
DG
