I've got a bit of a predicament, I have 1 vacuum port on the intake for the brake booster, 1 port on the back of the carb (Holley 750 0-80573S) for the PCV line, 1 timed port for the vacuum advance, and a manifold vacuum port on the bottom of the carb. As per this picture http://www.jegs.com/photos/500/510/510-Supercharger_Carbs.jpg , I need to hook up the power valve port to a manifold vacuum. Is it safe to hook up both this and my trans modulator using a Y connector to the bottom carb vacuum port?
Thanks.
Thanks.
