I don't read a lot of magazine articles. In fact, I don't even have any subscriptions to any car magazines. I believe that a number of articles are merely a disguised means to advertise aftermarket car parts, and nothing more. However I came across what I think is a pretty good tech article in the Chevy Hi-Performance magazine that I located on the INTERNET, which is about using cranking compression pressure readings taken with a compression gage to determine camshaft choices vs. static compression ratio compatibilities for running engines on pump gas.
I'm merely sharing this with those of you who might be contemplating a new engine combo for a street car to be run on pump gas, who might also be interested, and would want to or even need to broaden your understanding on static compression ratio requirements for pump gas, and how they relate to dynamic compression ratio requirements, and camshaft valve timing specs and duration specs. These topics are touched on in the article also. So please don't be completely caught up with the concept of determining pump gas compatibility with a compression gage. Even though the article is about that for the most part, the reason that I'm posting a link to the article is merely because it gets into explanation of how camshaft duration specs and more specifically, valve timing specs can and will make an engine pump gas friendly, or unfriendly to pump gas.
This isn't the end all article, nor the last word concerning pump gas engine requirements by any means. I just believe that it can be of help to those of you who might be new to these concepts, and who might be assisted in your future engine building choices by the knowledge of the things mentioned in this article.
DISCLAIMER:
Keep in mind that the article mostly covers basic concepts, and doesn't get completely into every minute detail nor tricks of the trade of engine building. I'm merely posting this, that it may me be of help to some of you who aren't familiar with the things contained in the article. I believe there are too many threads here in Team Chevelle which start out with somewhat simple and novice questions that require merely basic answers, but then get taken waaaay off topic by some who want to jump in and make claims about what they have accomplished, but who do NOT want to tell the whole story nor share details, nor the tricks of the trade that they have applied to be able to accomplish what they have.They merely wish to debate in order to somehow prove that their theories are correct rather than be of help to the original poster who asked for help. So the purpose of such threads are therefore lost and/or undermined, when they merely were started as a means for one person to ask for some help and advice on some basics. Enjoy.....
http://www.chevyhiperformance.com/techarticles/81679_tuning_engine_compression/index.html
DISCLAIMER:
