Everybody experiences it but I want to know why it happens and if it can be corrected.
At cold temp oil PSI is maxed out at 65psi at 1100rpm. When at 195 deg F and 800 rpm psi is 7-10 psi (yeow-za!) When rpm is increased to 1100 rpm psi is only 40 psi I'm using Mobil 1 but it happens with 10W-40 or straight 30W. I understand viscosity vs. temp but come on! Is it a function of my oil pump bypass spring or what? Bearing clearances? Pump is new as is 454 rebuild.
