I have and issue with the power steering pump hitting the gearbox. When i first got the car it had manual steering so i decided to upgrade to a JGC gearbox and got a P/S pump but after trying to install it the pump hits one of the bolts off of the gearbox. Also the pump comes into contact with the pump line and won't let me pull the pump any further back in order to get it nice and tight.
The lower bracket is correct for the 68 block that i have. It also has a short water pump with alternator on the driver side which makes avoiding the belt that is on it hard. I can grind down the bolt to get me some room but the hard line is another matter. I don't understand, is the gearbox bigger than the earlier GM versions? Below are pictures.
