1 - 11 of 11 Posts
I have a 496 short block. that I want to use as a spare for my car . or somthing in the future. I plan on using AFR 315 cnc for my heads and a dom 1050 that i have. the short block is a gm mk 4 block and eagle 4340 crank and h b rods . the pistons are srp 12.8 comp looking for the most i can get out of this size engine . looking for a solid roller cam recommendation and any other advise on this build any 496 running the same parts . tell me what you got .
See the 489 link in my sig below. The cam is an Isky custom grind. R649 intake lobe (.736"/272*), R469 exhaust lobe (.714/280), gound on a 108 LSA. The intake looks a little on the short [email protected]", but if you look at the the .100,.200 etc. numbers, you can see it is a pretty aggressive lobe.
If I had it to do again I might go a little shorter on the exhaust lobe, R467 is .714/276. Might make a little more TQ that way. This is with 1.7 rockers.
See the 489 link in my sig below. The cam is an Isky custom grind. R469 intake lobe (.736"/272*), R469 exhaust lobe (.714/280), gound on a 108 LSA. The intake looks a little on the short [email protected]", but if you look at the the .100,.200 etc. numbers, you can see it is a pretty aggressive lobe.
Hey Jay,,
How about 649/469 ;)
And if you profile these lobes you will find they are 2-3°'s bigger at .050 than advertised on a rat core.
Hey Jay,,
Duh, your right. R649! It would be a 496, with 649 and 469 lobes.:wacko: Don't know how I got THAT mixed up! LOL. I've had to work very late the last three days, so I'm going to blame it on that! I do have a cam doctor sheet(stack of sheets) on the cam, I'll try to decipher it and see what it shows. This same design is going into a slightly larger engine soon but on a 111 LSA and with a 1.8 rocker on the intake. Should be on the dyno soon. I'll report the results.
I know that it will be a stretch wondering if you could run somthing like this engine on pump gas mainly to see what you could get away with running at something like the PGD like hot rod mag is putting on .
Not at 14.3:1. There a many variables to getting max power on pump gas. I couldn't even start to guide you on all of that. Basics are pretty obvious, beyond that I would refer to an experts opinion.
1 - 11 of 11 Posts
