Hello,
I bought these and the 3 bolt collector part is not welded onto the pipe. Do I need to weld those on or is it ok if they are loose and just bolt up? Will the gasket be enough to have a complete seal between the 2 flanges or do I need to have the flanges welded on? I have an 02 sensor that I'm sensitive about having any exhaust leaks so that is what I'm concerned with.
Thanks,
Rick
