OK carb question I have a 468ci
open plane manifold
990 heads 2.19in/1.88ex valves
13:1 comp
all forged internals
cam solid roller 272in/278ex @.050 775in/768ex lift with 1.7 rockers
super compatition headers
not now but will be adding a 300hp nitrus kit
what size carb would work best
AED 850HO
AED 1000HO
or suggestions ?
this will be going in the car in my sig as it sits now same gears and tires and trans but with a 4200-4500 stall converter.
Thank You
Banned
BG825 with a 1.75" butterfly and 1.425" venturii
Holley 950 with a 1.75" butterfly with a 1.375" venturii
Or have a 950 holley main body cnc machined to 1.425"-1.450", Pro Systems could help you out with that
of the two you listed ,i would go for the 1000ho . OR an equivalent out of the box holley hp1000 . Looks like you should knock off 2 seconds from your previous best .
I have a similar combo but with a little smaller lift cam and ordered a prosystems carb. They recommended a 1000 cfm 4150 for my application. I hope that helps, give Patrick a call.
AED will stand behind there carb,just an fyi.I am running a Holley 850 on my 468 now with a best of 11.53.I plan on moving to a 1000 HO. Mainly for growing room.
