If you need one more dyno and drag test to look forward to...
1970 MC
4110 lbs
Original TH350 and converter
Locked, 2.56 12-bolt
Current 467 (estimated 450-460 hp) showing about 380 hp running 13.0 @ 108 mph, best 60’ 1.98.
In case you’re wondering about the disparity between max hp and hp shown in the quarter, think about the gap between the stock stall and peak hp with 2.56 gears. 1st gear, 5400 rpm is about 66 mph, the trap comes at about the same rpm in 2nd gear. The car is nearly a dead hook with the 255/60 Kelly Charger radials.
Anyhow, here’s where it gets exciting...placed an order with Mark (VortecPro) for a stock-appearing stroker. He’s confident it will still go over 600 hp with headers, even with the cast iron intake and QuadraJet carb.
I’ll give updates along the way, as things get closer, in the meantime, I’m open to your thoughts on the challenge.
Fuel system seems to be high on the list. I want to see how this pans out.
Maybe driveshaft/u-joints? I won’t be anywhere near a critical rpm, but the driveshaft/u-joints will be putting in overtime if the tires hook up.
For quick reference, 6000 rpm = 74 1st gear, 120 in 2nd with a 26.5” tire.
The question we will hopefully answer this year...will it run 11s or quicker as the car sits? Once this is determined/confirmed, will it run 11s with exhaust manifolds in stock appearing trim?
Needless to say, I’m fairly excited.
1970 MC
4110 lbs
