SO I did what Rick said .....and to Rick#2, sir I do believe we both have a simple 1:1 linkage. I mean mine opens at some % primary opening not 1:1 with primary opening, but I was assuming PROGRESSIVE means opens at a quicker rate? .
Mine, anyway, with the same relatively straight linkage between the two, seems like 1:1. CLEARLY not progressive. test yours to see. ( I only did it once slowly as with snow flying , itll be days before the oil can get warmed up)
PS, in pic #2 you see that gap that shows in front of the arm in the secondary throttle, that sets the point of opening. Yours is pretty tight as compared to mine, it appears..
Maybe I am mistaken ,a s the new EFI stuff speaks of progressive as simply not 1:1 but at some % opening. In OLD SKOOL term, I thought it meant the secondaries ramp up quicker in arc than the primary. Height in the throttle arms does this in multi carb setups
Hopefully Chris will chime in and clarify.
