X2 on calling Mark first to see what changes he’d recommend for the engine.
Depending on what kind of power you want to make, could go with a smaller D1-x, next up would be a F1. Procharger guys are good to talk to about what could work for your hp goals.
Going multiport EFI will help with fuel distribution and give some help against a cylinder going lean under boost. But, boost creates heat and you lose intake air cooling with MPFI, unless you plan on running E85. If not E85, could use methanol injection to keep heat down assuming lower boost levels. Likely looking at needing an air/air intercooled setup above mild boost levels on pump gas.
Approaching 1000 hp under boost requires a
stout fuel system, so that will have to be substantially upgraded from where you are now, even more so if going E85.
Then have to make sure everything downstream of the engine can handle the added torque you’ll be putting out - trans, driveshaft, differential.
You’ll need to think about your brakes if currently vacuum assisted off engine vacuum, because that goes away with boost. Likely need a vacuum pump, hydroboost, or go manual.
Also, given the pulley configuration with the procharger, nearly all setups I’ve seen use electric radiator cooling fans.
All doable, just needs planning. Good luck.
